Carb Trouble Junker Crappy Talon 150CC Dekni Carb
Old Jun 16, 2007 | 08:07 PM
blackops's Avatar
Default Carb Trouble Junker Crappy Talon 150CC Dekni Carb
[img]i/expressions/face-icon-small-confused.gif[/img]
Ok brand new. Ran well for about 3 hours, then statrted sputtering. Made it home. Drained gas, filled, checked spark, float, jets, ground, electrical, factory adjust is set, all lines and screws tight. Will start and run poorly for about 3-10 seconds, then dies out. The bypass electrical (choke) I don't know how to test. The valve from the tank has fuel valve on top and vacuum on bottom, again don't know how to test. Dealer is being very snotty about it.
Any help is appreciated........
Ron
Old Jun 18, 2007 | 01:10 PM
mustangs351's Avatar
I had ran into this same problem on my friends bike(banshee). he took the carb off and discovered trash in the carb internals.He used carb cleaner to clean it out and no problems since.If that is not the problem and it is getting fire then i would think the choke is stuck. On some electric choke carbs they will have a way to manually manipulate the choke. I hope this helps.
Old Jun 18, 2007 | 10:02 PM
blackops's Avatar
Hi,
Thanks much Mustang - but been there, done that.[img]i/expressions/face-icon-small-mad.gif[/img] Any one know a suitable replacement that would bolt-plug in? This one is going to be target practice if I can find a replacement. It is a 24mm with vacuum on top and passenger side. Then the bypass electrical unit.
I will pay cash for a decent one that works.
Thanks
Blackops
Old Jun 20, 2007 | 12:10 AM
i went online and found a few places that carry carbs @ parts. i'm assuming you have a talon 150 2 seat go cart. i do not know exactly what your part # is so i had to guess,but i found a good site that carrys ALL of manco's spare parts. go to jacks small engines .com. It was a pretty good site i would probrobly be able to find your part if i knew the part #.I'm no smartass but im pretty good at finding stuff online.
Old Jun 20, 2007 | 08:29 PM
blackops's Avatar
Mustang-
Greetings. Part#? yeah right.....there are no part numbers....I am serious, nada, zippo, zilch.
TO ANYONE OUT THERE INTERESTED IN A TALON OR HAS BEEN THINKING ABOUT A BUGGY.....>>>>>>>>>> >>>STAY AWAY FROM CARTER BROTHERS AND TALON BUGGIES.
tx M
Nondem
Feb 22, 2020 12:20 PM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
