ds-650 woes
Old Jun 16, 2007 | 09:21 PM
truckdriva's Avatar
Default ds-650 woes
new to the can-am world. does anyone know how to tighten the chain on an 01 ds-650? all ive ever owned are honda's
Old Jun 16, 2007 | 10:10 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
Default ds-650 woes
Loosen the 2 bolts on the back of the swingarm till good and loose. The take a philips screwdriver and stick it into the carrier holes through the sprocket. Once sprocket hooks up with the phillips you can move the quad (in nuetral) forward or backwards to tighten or loosen..
Old Jun 16, 2007 | 10:29 PM
DragonDJ11's Avatar
Default ds-650 woes
If it is a stock swingarm, should have 4 bolts.....
Old Jun 17, 2007 | 12:35 AM
truckdriva's Avatar
Default ds-650 woes
thanks guys! I just bought this bike at a government auction. It was 3 months old when it was seized in july, 2001. It sat at the impound yard for 6 years untill I bought it in april. After I tuned it up, rebuilt the carb, and cleaned the tank, it fired right up. I rode it for about five minutes and it spit out the rear bearings. I only paid $2000.00 dollars for it so I guess I'm still in the good.
NickDS650's Avatar
Default ds-650 woes
2001 swingarm, 2 bolts. It will be easier for ya to prop it up off the ground so all u gotta do is spin the rear tires to tighten/loosen and watch the chain to desired tension
Old Jun 17, 2007 | 01:35 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Default ds-650 woes
Also if its 01 don't get your bearings from a dealer go to KAMAN INDUSTRIAL SUPPLY AND GET A BETTER QUALITY BEARING.You will be happier.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 17, 2007 | 01:25 PM
Easter's Avatar
Default ds-650 woes
ya i bought bearings from kaman for $6 when it would of been $40 from the dealer and the quality is much better and its cheaper as AZSAND said
abealz
Mar 13, 2024 11:39 AM
salixair
Nov 3, 2015 08:25 AM
7QuadSport7
Dec 19, 2004 11:19 PM
GLWBEAR
Dec 21, 2003 10:17 PM
HellRider
Sep 29, 2003 08:04 AM
