Mud Bug tires on 700EFI?
Old Jun 17, 2007 | 10:58 PM
16polaris's Avatar
Default Mud Bug tires on 700EFI?
I like the looks of the Maxxis Mud Bug 27" tires. I want to put a 27x9x12 on the front and a 27x11x12 on the back. Will this setup work with the stock suspension and has anyone used this tire and how did it perform?
Thanks!
Old Jun 17, 2007 | 11:01 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i know a guy who had them on a cat, and the guy i went w/ sat. had them on a suz k.quad and they do well in the mud. the only bad thing about them is there soft compound and will were down fast if you ride on alot of hard pack and rds.
Old Jun 17, 2007 | 11:28 PM
16polaris's Avatar
will I have any problems with the size I want to run?
Old Jun 18, 2007 | 07:53 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
w/ 27" on, you shouldnt have any problems except for the front 9" may rub on the strut.
Old Jun 18, 2007 | 01:22 PM
RolliePollieOllie's Avatar
I run 27/9/14 Mudlite XTR's on my 2005 SP700 with no issues of rubbing. Not sure if this condition is different with the 12" rims however.
Old Jun 18, 2007 | 06:25 PM
DONECRASHED's Avatar
I run the same tire size that you are looking at on my sp700 with 12" rims. I run Swamplites and have no rubbing and plenty of clearance.
Old Jun 19, 2007 | 12:24 AM
16polaris's Avatar
should I add a set of 1" wheel spacers?
Old Jun 19, 2007 | 07:57 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if your going to use stock rims try them on first and see if they rub or have no clearance and go from there. if they do rub then you have to add the spacers. i just bought the wheel big foot kit so i didint have to worry about that.
Old Jun 19, 2007 | 06:39 PM
Reloader's Avatar
I've ran the Mud Bugs on a Yamaha.
I wish I'd have know they ran small for the size stated before I bought them. They pull great in the mud but, I took them off after a few months because I wanted a larger tire.
They ride fine on hard surfaces and pull well.
If you buy the 27s they'll be the size of some other brands 26s. Not that big of a deal but, they should make them the size stated like Interco.
Good Luck
Reloader
Old Jun 27, 2007 | 10:51 PM
16polaris's Avatar
Donecrashed, How do you like the Swamp Lites? I really like the looks of them.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
