Please help with 06 Kawasaki KFX-80
Old Jun 18, 2007 | 01:30 PM
chrisk500's Avatar
Default Please help with 06 Kawasaki KFX-80
I recently removed the speed limiters on the kfx-80 and now can't get the thing to run right. I removed the exhaust restrictor and the throttle cable limiter. The problem is it will run fine until it is trying to go up a hill and then the thing will bog down and giving it more gas seems to make it go slower and will then die on me. Sounds like maybe a carb problem. Any ideas? I replaced the spark plug and stil the same problems! Sucks having issues with a "brand name" quad. Hopefully an easy fix!
Thanks for your help!
Old Jun 18, 2007 | 08:12 PM
LT80's Avatar
LT80 Expert
Did you get the carb slide in correctly? Put the slide together correctly?
I've seen both happen. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 22, 2012 | 10:48 AM
JewishReindeer's Avatar
I have the same problem on my bike and its a kfx80 to me and my dad thinks its the floats in the carb but i do not have the manual so its hard trying to get the float set to the right height
Old Sep 22, 2012 | 04:30 PM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Maybe if you start a thread on what is wrong and what you've done to test/fix it.
This thread is 5 years old.
wendal
May 9, 2024 09:29 PM
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
shimanok2
Jan 29, 2016 07:37 PM
wendal
Sep 15, 2015 01:50 PM
