DS650 Reving high when warm why???
Old Jun 21, 2007 | 02:49 AM
Tapper1823's Avatar
Default DS650 Reving high when warm why???
My ds650 runs great but then in a bout ten or fifteen minutes it revs really high and it wont stop unless you let it sit for awhile. could this be a jetting issue but its weird it only does it when it get warm. help would be appricated thanks
Old Jun 21, 2007 | 12:09 PM
blj09's Avatar
I have a DS650 and run it for hours with no problems with high rev. The only thing that makes sound when it gets hot is the air fan to cool it off. If your reving high it might be a problem with you Jet Kit.....
Old Jun 21, 2007 | 01:06 PM
NickDS650's Avatar
it revs up by itself when ur ridin it or if its just sittin?
Old Jun 21, 2007 | 01:43 PM
Tapper1823's Avatar
if im just sitting there it revs up and when im riding it does it too but only after like ten minutes of riding then i let it sit and its fine again for another then minutes
Old Jun 21, 2007 | 02:50 PM
DuneRider650's Avatar
I ride a little here and there......
take out ur needle/carb slide assmebly some of that dyno junk prob messed up.
Old Jun 21, 2007 | 04:19 PM
Tapper1823's Avatar
If i do that then how do i know what i need to fix or if i did anything wrong the diagram sucks with the dyno jet
Old Jun 21, 2007 | 05:11 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
This could all be a cable problem. When it gets hot the gunk in the cable gets sticky and gives the effect of a sticking throttle. Been there, done that! Buy the adapter for the cable for around $4, can of carb cleaner, can of cable lude or everybody's favorite Wonder Drug 40, hose that bad boy out real good, flush with your preferred lubricant until it's coming out of the other end, and walla!
And if that doesn't fix the problem then atlest you've ruled that out, and have a worry free throttle cable as a result.
Let us know what you find. Sometimes it's the simplest things that trouble us the most.
Old Jun 21, 2007 | 05:14 PM
Tapper1823's Avatar
what is that adapter for the cable?
Old Jun 21, 2007 | 05:20 PM
aceisback's Avatar
Military Rider
You can get it at any bike shop or auto parts store. Just a clamp with rubber guts and a hole for the extension tube from the cleaner/lube. Forces the liquid down through and out of the end of the cable.
Old Jun 21, 2007 | 05:22 PM
Tapper1823's Avatar
what would i ask for if i was going to buy one from a bike shop? thanks
