grinding cluch????
Old Jun 22, 2007 | 08:54 AM
jetmotoracer's Avatar
Default grinding cluch????
hi, when i go from nutral 2 1st sometimes the cluch/gears sound like there grinding is this because maby im holding the cluch in to long or is it messed up... cuse it only does it when i seem to hold it in long.
Old Jun 22, 2007 | 11:02 AM
outofline's Avatar
sounds like you need to adjust your clutch. If your in Neutral and you shift into 1st and the quad feels as if it wants to move then your clutch is not engaging enough.
Old Jun 22, 2007 | 06:12 PM
do you mean disengagedor or i just have it backwards??? and how do you ajust it???
Old Jun 22, 2007 | 07:11 PM
outofline's Avatar
When you have the clutch lever pulled in and in first gear when you let out the clutch how soon does the quad want to roll. It should be when your clutch is approximately half way from the handle grip to all the way out. If it's right when you start to release it then you need to adjust it so it releases a bit later. if it's right to the end you may find the clutch will slip when you gun it in first gear.
You can adjust the clutch at the two nuts where the cable is held to the motor, adjust one way and it will change it at the lever so play with it til its right where it needs to be.
Old Jun 22, 2007 | 07:39 PM
o thanks!!!!!
flyin-lowe
Dec 1, 2017 03:18 AM
bvandass
Oct 8, 2015 09:13 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Minimod
Sep 10, 2015 08:03 AM
Dan Newberry
Aug 30, 2015 09:42 AM
