400ex stalls in water
Old Jun 22, 2007 | 02:36 PM
mizzou_17's Avatar
Default 400ex stalls in water
I have a 400ex and every time i ride in very deep water it stalls out, any advice?
Old Jun 22, 2007 | 02:37 PM
mizzou_17's Avatar
I read on one page to relocate the carb vent hose does this work?
Old Jun 22, 2007 | 02:56 PM
scootergptx's Avatar
Supersock
Hired Gun!
Try putting some dielectric gel on the spark plug boot.
You should be able to pick up a small tube at Auto Zone or any parts store.
Also, when you go in the deep water, is it getting into the airbox? You could put a snorkel on the intake. But I don't think I've ever seen a sport with a snorkel.
Old Jun 22, 2007 | 02:59 PM
mizzou_17's Avatar
the gel wont effect the spark or cause it to jump spark will it?
Old Jun 22, 2007 | 03:00 PM
Supersock
Hired Gun!
No, it will keep the water out of the plug wire, and keep it from shorting the spark out.
Old Jun 22, 2007 | 05:23 PM
mizzou_17's Avatar
what about the carb vent hose does anybody have any info on that? does it really work/ and where do you relocate it to?
Old Jun 22, 2007 | 05:28 PM
muddstudd's Avatar
how deep of water are you crossing if your worried about the carb vent hose? i'd say relocate it to the air box.
Old Jun 22, 2007 | 05:30 PM
mizzou_17's Avatar
the water is about 3/4 up on the tires but it is cutting out real bad, would the vent hose cause that?
Old Jun 22, 2007 | 05:32 PM
Supersock
Hired Gun!
The carb vent hose should have a one way valve on it if I'm not mistaken. So getting water back through it would be unlikely.
Now, the line you're looking at, is it on the bottom of the carb? If so, that is just the carb drain line. The vent line should be up by the airbox.
Old Jun 22, 2007 | 05:36 PM
mizzou_17's Avatar
it may be the drain hose im seeing does it have a check valve also?
