Anyone use this Big Bore Kit?
Old Jun 29, 2007 | 02:54 PM
derrick2v's Avatar
Default Anyone use this Big Bore Kit?
Since i have to rebuild, i was looking on ebay and came across a 720 Big Bore Kit for 369 from Pease Custom Performance Offroad Inc. Im wondering has anyone on here used them? Is 175 a reasonable price for them to Resleeve, finish bore and hone my cylinder? At this time my DS is completley stock, if i would go this route what would you guys reccomend to add with this i wanna keep it reasonably priced and also somewhat trailable. I was thinking diff carb not sure what size? and a ported intake? Not sure what kind of exhaust to go with, or could i run an aftermarket tip on the stock exhaust? Any suggestions would be greatly appreciated.
Old Jun 29, 2007 | 03:38 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
I hear the sleeve is still in testing, But for the money you cant go wrong per hp gained. But you need to make sure they do it right. If not it could cost you big money.
BTW- I think that is ERBE's Kit he put together. He has custom grind cams too. Hopefully he can chime in and save you some money and trouble for this particular application.
Old Jun 29, 2007 | 05:07 PM
derrick2v's Avatar
Yeah definitly sounds worth it, i know from experience with my snowmobile about having someone do the machine work, if its not done right it will cost ya $$$$.. anyways yeah hopefully he will chime in and can fix me up good[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 3, 2007 | 12:08 AM
ERBEDS650's Avatar
no problems with my Alum sleeved 720 still chugging along, cost ya a bit more than 370 about 420 just to be sleeved plust your piston cost.
Old Jul 6, 2007 | 08:31 PM
derrick2v's Avatar
i dont understand why they say they will resleeve it for 150 if you send it to them, i thought that was pretty low???? 420 sounds more what i was thinking....?????
Old Jul 6, 2007 | 11:26 PM
ERBEDS650's Avatar
Contact Kurt Koppelmann [kurt@mt-llc.com] at Millennium Technologies you have two ways of doing it, Bore and plate as scooby did, his cylinder just broke he was running over 120 HP on his, mine was bored and aluminum sleeved, been running it now for 6 months with no problems with a 13 to 1 piston, The BOM can get you a 102mm-700cc or a 105mm-720cc piston you tell him what compression you want, just use a cometic gasket kit, good luck!
Old Jul 7, 2007 | 12:28 AM
BBR650's Avatar
Is always changing bikes.
i think derrick2v is talkin about the steel sleeve cyl. if so i know of 2 bikes that have had those installed and one worked and the other had continuous head gasket failure. if you talk to the BOM he will advise against the steel sleeve.
erbe- what kinda hp gain did you get with the big bore over a stock bore with the same setup????
Old Jul 7, 2007 | 02:46 AM
ERBEDS650's Avatar
its not just the 720, pipe carb, cams head porting, Im having another set of cams dynoed next week, ill post the readings then, last time was Max HP was 64 @ 7900 and signs off like a nose bleed at 8500. Max torque was at 54 ftlbs.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
