need new rings bad
Old Jul 10, 2007 | 05:51 PM
orangebomb's Avatar
Default need new rings bad
need new rings for a 14:1 piston that was bought from mr hp. Were can i get a set other than research hp ? i dont remember if the piston was marked by a manufacturer .
Old Jul 11, 2007 | 10:23 AM
Hightower's Avatar
HPR did a lot of work in having their pistons made custom, by JE I think but not certain, but it is not a typical run of the mill shelf piston. for this reason, it may be best to get the ring package from them, so that you are certain that the ring set you get is exactly right for the piston.
Old Jul 11, 2007 | 10:39 AM
MRDS650's Avatar
Canadian and Proud of it !!!
Your best bet would be to try Eric (Mr. Horsepower) @ Oldham Machine Works. You should be able to throw a post up at On-dunes (he has his own section there) to get a hold of him.
Old Jul 11, 2007 | 01:54 PM
Scatterbrain's Avatar
They are from JE. Try Eric first theres quite a few different ring set part numbers. You need to make sure you get the right ones. If you cant get through call JE directly, Took a bit of work but I finally got the right ones for my 730.
Old Jul 11, 2007 | 07:26 PM
orangebomb's Avatar
thanks for the info guyes!!
Joe454
Nov 20, 2020 01:19 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
bvolks
Sep 13, 2015 12:57 PM
Steeldon
Sep 9, 2015 09:38 AM
