atc 200 timing
Old Jul 11, 2007 | 03:15 PM
dgcrsn11's Avatar
Default atc 200 timing
I am rebuilding my atc 200 and i would like to know how to set up the timing right when i put it back together??? Thanks
Old Jul 11, 2007 | 11:32 PM
dgcrsn11's Avatar
anybody??????
Old Jul 12, 2007 | 02:21 AM
KNOWSALOT's Avatar
The Facility
Align the "T" mark on the flywheel with the notch on the case. You will have to remove the timing inspection cap to see this.
With that done, keep the flywheel still and align the "O" on the camshaft sprocket with the notch on the top of the rockerarm cover. You will have to remove the CDI cover and assembly to see this notch. (It will already be removed ofcourse but Im pointing out the easiest way to find these marks)
Confirm that both lobes on the camshaft are pointing downward at this point. If not, remove the 2 cam sprocket bolts and turn the cam a full 360 and it should be pointed downward and your "O" mark still on the notch of the rocker cover. (straight up) Also be sure the flywheel is still set to "T".
Old Sep 15, 2008 | 11:43 AM
big red 1984's Avatar
Default atc 200 timing"></title><script src=
hello i have a 1984 200 es big red can someone tell me where the timing marks would be and how to set them up thanks
Sjrpp
May 2, 2023 03:59 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
