98 warrior
Old Jul 12, 2007 | 01:38 AM
rogerd72's Avatar
Default 98 warrior
i might be getting a 98 warrior with a rebuilt top end dg excelerator full exhaust and k&n filter but the guy told me over the phone that it shoots flames is there something wrong with this atv and will it be hard to fix its cheap oh and its got after market gearing i have seen other bikes do this before.my stepsons dad said its cause theres no baffeling inside the pipe is this true?
Old Jul 12, 2007 | 02:54 AM
Oldbutslow's Avatar
Default 98 warrior
There are two possibilities. The first and most likely is that when they were rebuilding they didn't have the sprockets for the timing aligned and its allowing the exhaust valve to open before the fuel is fully burned. It builds up in the exhaust and ignites occasionally shooting out flames. This isn't a big problem IF and only IF it didn't bend the valves. If it did its not worth much.
The second thing it could be is that its way over carburated and is getting too much gas. The motor can't burn it all so it gets sent into the exhaust where it burns. Minor re-jetting or carb rebuild, not too expensive but it can be time consuming.
Old Jul 12, 2007 | 03:11 AM
rogerd72's Avatar
Default 98 warrior
thanks how will i tell if the vavles are bent? when i go see it?
Old Jul 12, 2007 | 03:17 AM
SlowAzzRaptor's Avatar
Default 98 warrior
If it runs good, it probably has an exhaust leak (at the joint??) and that will let it suck air and back fire. If thats the case, it will only do it when you let off the throttle.
Old Jul 12, 2007 | 03:22 AM
Oldbutslow's Avatar
Default 98 warrior
Bring a compression tester (the screw in type with an air valve). Put the motor on top dead center (with the pistion all the way up and both valves closed), put it in first gear, block the wheels so the motor can't turn, remove the spark plug, screw in the compression tester, apply around 30 psi of air and see if it leaks out. It should take a long time for the pressure to go down (at least 15 min.). If it doesn't hold the pressure then the valves are not seating and you should run, not walk away.
If you don't know what I mean either take along a mechanic or bring it to a shop. It shouldn't cost more than $35, tell them you want them to to a leak-down test on the motor, and that you think the valves may be bent.
Old Jul 12, 2007 | 03:24 AM
rogerd72's Avatar
Default 98 warrior
guy seems pretty honest to me im not giving him cash for it he said it runs good that hes selling it casue he just bought a motorcycle and the wife said the 350 has to go but im going ask if i can putt around his yard if he wont let me then i know its something major thanks guys
Old Jul 12, 2007 | 03:26 AM
Oldbutslow's Avatar
Default 98 warrior
<div class="FTQUOTE"><begin quote>Originally posted by: SlowAzzRaptor
If it runs good, it probably has an exhaust leak (at the joint??) and that will let it suck air and back fire. If thats the case, it will only do it when you let off the throttle.</end quote></div>
He said its shooting flames, not backfiring. Although the guy on the phone could have meant backfiring, that would change things.
Old Jul 12, 2007 | 03:45 AM
Default 98 warrior
Back firing shoots flames. My Chevelle used to look like a flame thrower when I'd let off the throttle due to a crack in my header tube pipe.
11 times out of 10, if anything serious is wrong with this bike, it will show it in the performance. If the bike idles good and has good power, nothing major is wrong.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
