Rubicon choke
Old Jul 16, 2007 | 07:16 AM
22222's Avatar
Default Rubicon choke
I have an '02 Honda Rubicon. The problem is that when I pull the choke up prior to starting it does not stay in the fully out position. Is there a way to adjust it so that when I pull it up it stays until it's ready to be pushed down. Thanks.
Old Jul 21, 2007 | 01:58 AM
Mayorstt's Avatar
Hi , I have an 05 Ruby and mine did the same thing. I found out that there is a nut under the rubber coating just below the **** on the choke. You can take a pair of pliers and tighten the nut and it will fix the problem. I just squeezed the rubber coating and nut together and tighten just a little and it took care of the problem. hope you have the same luck I did. Good riding...
Old Jul 21, 2007 | 12:23 PM
22222's Avatar
Ahhh Okay I will try that......I had a feeling that it would be a somewhat simple fix. It's been kind of annoying in that I have to make sure I'm holding it up until it's warmed up or it will stall. Thanks again for your help!
Beeline08
Nov 11, 2016 04:00 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
