broke hotcam stage 2 at flex plate, can i weld????
need help now, engine in pieces, i was installing the hot cam 2, judt got it back from the machine shop and snaped the friggin end, can i weld it, will it hold at 11,000 rpms with a 13:1 cp pistion? if any one has a nother one i can buy that would be great.
The camshaft would only be spinning around 5500 rpm. I wouldn't recommend welding it. Cams are hardened and more than likely it would break on either side of the weld. I hate to tell anybody this but I think you're screwed on this one.
it would be spinning more that 5500 caus i have a +1000 cdi box ya i figured i was porked so i just orded a new one, this blows, but if one person reads this and now knows not to over torque bolts it was still, not event close to worth it, lol i hope my mistakes help some one
"it would be spinning more that 5500 caus i have a +1000 "
A camshaft in a four stroke engine spins at one half crakshaft speed. So was the camshaft over torqued to the cam sproket causing the break. How does it run with a 13:1 piston and are you finally beating your queen's 450?
Terry
Terry
The real question here is why are you planning on turning your engine 11K rpm's when you make peak power a couple of thousand rpm's lower. It's unnecessarily beating on your engine and slowing you down. More rpm's don't mean more power unless your engine is set up for the increased rpm's.
<div class="FTQUOTE"><begin quote>Originally posted by: JoeDanger660
need help now, engine in pieces, i was installing the hot cam 2, judt got it back from the machine shop and snaped the friggin end, can i weld it, will it hold at 11,000 rpms with a 13:1 cp pistion? if any one has a nother one i can buy that would be great.</end quote></div>
Sorry. Just going off your original post. Good luck on your quad and have fun riding.
