broke hotcam stage 2 at flex plate, can i weld????
Old Jul 18, 2007 | 11:20 PM
JoeDanger660's Avatar
Default broke hotcam stage 2 at flex plate, can i weld????
need help now, engine in pieces, i was installing the hot cam 2, judt got it back from the machine shop and snaped the friggin end, can i weld it, will it hold at 11,000 rpms with a 13:1 cp pistion? if any one has a nother one i can buy that would be great.
Old Jul 19, 2007 | 01:07 AM
rruser's Avatar
can you explain in detail what broke?
Old Jul 19, 2007 | 03:52 PM
fastquad02blaster's Avatar
The camshaft would only be spinning around 5500 rpm. I wouldn't recommend welding it. Cams are hardened and more than likely it would break on either side of the weld. I hate to tell anybody this but I think you're screwed on this one.
Old Jul 19, 2007 | 05:34 PM
it would be spinning more that 5500 caus i have a +1000 cdi box ya i figured i was porked so i just orded a new one, this blows, but if one person reads this and now knows not to over torque bolts it was still, not event close to worth it, lol i hope my mistakes help some one
Old Jul 19, 2007 | 11:32 PM
getblown's Avatar
"it would be spinning more that 5500 caus i have a +1000 "
A camshaft in a four stroke engine spins at one half crakshaft speed. So was the camshaft over torqued to the cam sproket causing the break. How does it run with a 13:1 piston and are you finally beating your queen's 450?
Terry
Old Jul 20, 2007 | 11:32 AM
garyc660R's Avatar
The real question here is why are you planning on turning your engine 11K rpm's when you make peak power a couple of thousand rpm's lower. It's unnecessarily beating on your engine and slowing you down. More rpm's don't mean more power unless your engine is set up for the increased rpm's.
Old Jul 21, 2007 | 08:31 PM
<div class="FTQUOTE"><begin quote>Originally posted by: JoeDanger660
need help now, engine in pieces, i was installing the hot cam 2, judt got it back from the machine shop and snaped the friggin end, can i weld it, will it hold at 11,000 rpms with a 13:1 cp pistion? if any one has a nother one i can buy that would be great.</end quote></div>
Sorry. Just going off your original post. Good luck on your quad and have fun riding.
Old Jul 24, 2007 | 02:29 PM
ds650ctracing's Avatar
I dont know much about stage 2 camshaft, but I would assume he is moving the power band up in the RPM range, that is the reason for the 11K.
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
