banshee idle problems
Old Jul 21, 2007 | 05:27 AM
T-daddy's Avatar
Default banshee idle problems
wen i start my banshee it wont stay running i checked the carbs and theres tors on them but there not connected jus wanted too no if this was the reason it wasnt idleing do i need to buy new carbs with a idle kit installed please help will appreciate
Old Jul 21, 2007 | 11:37 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
check the needle seat... how long are you letting it idle for before it dies?
Old Jul 21, 2007 | 09:20 PM
T-daddy's Avatar
it dosent idle i have to give it gas to keep it runnin and wen i let it go it shuts off in a bout 3 sec
Old Jul 21, 2007 | 10:39 PM
Speedy2222's Avatar
any fuel coming out of the overflow?
Old Jul 22, 2007 | 05:07 AM
T-daddy's Avatar
no fuel but i noticed some green liquid on the ground under the bike
Old Jul 22, 2007 | 11:00 PM
Speedy2222's Avatar
green = antifreeze
i would say check your float level.. i've noticed mine has been doing this also, however one of my carbs is worn out and is just DUMPING gas into the carb
Old Jul 23, 2007 | 12:37 AM
T-daddy's Avatar
wow were is the antifreeze at is it the bottle under the seat
Old Jul 23, 2007 | 02:59 AM
rruser's Avatar
I thought I posted about this but maybe it was on another site... If you did a carb rebuild make sure your slides aren't swaped between carbs. The slide from the left carb will fit on the right carb.. but it will be facing the wrong way. Same goes from right to left. Check it out.
Old Apr 10, 2022 | 01:24 PM
Colby122500's Avatar
I have the same issue with fuel coming out the overflow
Old Apr 11, 2022 | 03:10 AM
Don't know the Banshee at all, but fuel from the overflow means a stuck float needle. Usually just dirt between needle and seat. Easy fix. Turn fuel off, run engine until it stops, turn fuel on and the rush of fuel may dislodge the dirt on the now wide open needle. If that doesn't work, remove needle and clean both it and seat, checking for wear on needle and, if it has one, the little plunger in the needle, isn't sticking.
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
Jul 7, 2015 11:00 PM
MNatv89
Jul 7, 2015 11:36 AM
