02' Blaster problem
Old Jul 21, 2007 | 03:37 PM
steve 37's Avatar
Default 02' Blaster problem
I have just redid the top end on my sons blaster, and now it seems that it gets hot (top end) quicker, maybe its just me. The exhaust is making like a popping noise too. I checked the spark plug, and it looks like its not running lean (dark gray color). The cylinder was just honed, was not bored. I tried a bigger jet but it bogged at low rpm. So i went back to the mikuni 250 jet. runs better though. Any ideas? Or should i not worry about it, any help is appreciated.
www.mongoracing.com
Old Jul 21, 2007 | 08:15 PM
fastquad02blaster's Avatar
The popping is probably an exhaust leak on the front of your jug. Mine did that untill I tightened them, after almost loosing my exhaust on a ride. I'm not sure on your heat issue though. If you just honed it it shouldn't run hotter. More power means more heat though.
Old Jul 21, 2007 | 09:46 PM
steve 37's Avatar
O.k. I will check that. I did replace that gasket, since it came with the kit. Its a pro circuit 304 exhaust with pipe. Even with an after market pipe, it should seal like a stock one right ? Thanks man!
www.mongoracing.com
Old Aug 6, 2007 | 01:16 AM
steve 37's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: fastquad02blaster
The popping is probably an exhaust leak on the front of your jug. Mine did that untill I tightened them, after almost loosing my exhaust on a ride. I'm not sure on your heat issue though. If you just honed it it shouldn't run hotter. More power means more heat though.</end quote></div>
Thats what it was ! Had a bad spring on the right side (broke). Thanks
www.mongoracing.com
Old Aug 6, 2007 | 08:47 AM
No problem. Just an educated guess.
Frisky2050
Apr 9, 2020 11:19 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
joeyupton
Jul 14, 2015 11:51 AM
