94 polaris 300 explorer
Old Jul 24, 2007 | 12:17 AM
coachs's Avatar
Default 94 polaris 300 explorer
I was riding my 4 wheeler everthing was fine and the next thing I knew it wouldn't go anywhere it was like someone shifted it into neutral. Once it cooled down for a while it would take off again only to do it again after it warmed back up. Any ideas where to start looking? I took my cover off to look at the belts but they looked fine. Thanks
Old Jul 26, 2007 | 11:47 PM
coachs's Avatar
why don't anyone try to help?What good are forums if nobody wants to help each other
Old Jul 27, 2007 | 07:32 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you said you checked the clutches and they were working correctly, then something in the tranny but sorry to say i wouldnt have any idear.
Old Jul 31, 2007 | 09:22 AM
drewchips's Avatar
I would suggest driving with your clutch cover off. Obviously you need to do this very carefully so as to not have an loose apendages come into contact with the spinning clutch hubs! If you do this you can watch both your primary and secondary clutch hubs to see what is going on. It could be that your belt is improperly alligned and when it heats up it is starting to slip. If it is improperly alligned it is just a matter of time before it wears and breaks. I would doubt you are experiencing a transmission issue. As long as your tranny has the proper level of fluid in it, the symptoms don't seem to point to a tranny problem.
When you drive with the clutch cover off and it stops. Turn the engine off and put it in neutral. Can you turn the driven clutch by hand or is it tight?
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
