how hard is it to replace the pull starter
Old Jul 25, 2007 | 11:57 PM
jorb's Avatar
Default how hard is it to replace the pull starter
my pull start rope will not recoil, is it very difficult to replace?
Old Jul 26, 2007 | 02:32 AM
02huntinquad's Avatar
i broke the stock piece of string that cam with my quad. the polaris dealer told me i have to buy a whole new assembly for $300 or more. all that is in there is a spring wrapped around the pull cord assembly. if yours won't retract. i would take the cover off and spray some wd40 in the spring to losen it up so it retracts (cause you don't want to take it apart and rewind the spring, big pain in the butt)
if you want to replace it, it is about 8 bolts to undo and the shifter linkage
Old Jul 26, 2007 | 11:03 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
either the spring unhooked or broke or is bound w/ maybe rust or something. it just unbols i beleave and worse case you could take it to someone to take apart if you dont feel comfortable doing it your self as the spring can be tricky.
Old Jul 31, 2007 | 09:26 AM
drewchips's Avatar
They are very simple to replace and can even be repair most times. There is a small hook on the end of the wound spring. That hook takes all the pressure of the spring when you pull your starter rope out. The failure point is usually that little hook (just a bent piece of the spring in the center of the coil). You can rebend what is left on the spring if you take it off and reheat it with a torch. Make sure you reheat it before bending it though because springs are very brittle metals and that end will likely just snap off if you try to bend it without reheating.
Old Oct 15, 2007 | 01:12 PM
jpmor1's Avatar
How do you reattach the rope wheel to that little hook? I tried but couldn't get mine to line up right. Then the spring came all the way out. Is there an easy way to get it back in?
Old Oct 15, 2007 | 07:58 PM
rescramble's Avatar
i know your pain as my cam came through the side of the housing. iI just pulled the rest of the guts out and sealed the holes with rtv black. I also make sure i have a good battery before i go out. The assembly lists for around 240$. Check out Breese Lawn and Garden in Breese, Il. He has most parts in stock and this part you can get for around 180$ if needed.
Old Oct 15, 2007 | 08:59 PM
94harley's Avatar
I sent you a pm.
bikedad3
Jun 29, 2015 08:58 AM
Stillonit
Jun 18, 2015 11:23 AM
DOAinNY
Jun 11, 2015 10:34 PM
clsharky
Jun 8, 2015 11:38 AM
