1987 350 WARRIOR
Old Jul 27, 2007 | 10:26 PM
IRONHEAD MYKE's Avatar
Default 1987 350 WARRIOR
SORRY ABOUT THE NEW POST, DID WHAT YOUALL SAID. WENT OUT
AND PLAYED WITH THE PARKING BREAK,AND IT FIRED UP. INFACT IT
FIRED UP AND REVED ALL DAY. TOOK THE PARKING JUNK OFF THE
BIKE AND IT WOULD FIRE AND REV FIRST PULL EVERYTIME
MY BROTHER IN LAW JUST STOPPED BY FOR A BEER AND I SAID
"I FINALLY GOT THE WARRIOR RUNNING, CHECK IT OUT BRO" WENT TO
THE GARAGE, LIFTED THE COMPRESSION RELEACE, TURNED ON THE GAS
TURNED ON THE SWITCH, AND LOW AND BEHOLD, ITS THE SAME OL SAME OL
STILL SPUTTERING,BACKFIRING, AND WONT REV. I THOUGHT I HAD THIS LICKED
BUT NO, ANY OTHER IDEAS LIKE VALVES,SWITHES,ANY WIRING THAT MIGHT CAUSE THIS?? THANKS FOR YOUR TIME IRONHEAD MYKE
Old Jul 27, 2007 | 11:57 PM
mbogosia's Avatar
Mike, have you looked at your spark plugs? I wonder if your running rich and that is your problem. If your plugs are black then you are rich. Do you have any air box or exhaust mods and if so have you done any jetting?
Old Jul 28, 2007 | 03:20 AM
HEY BRO
2 THINGS, I TOOK THE PLUG OUT TO LOOK AT IT (ITS A NEW PLUG)
AND THE TIP OF IT IS BLACK,NOT CARBON BLACK, BUT KIND OF LOOKS
LIKE IT S GETTING HOT? THE REST OF THE PLUG LOOKS NEW.
I DONT HAVE THE ORIG. AIR FILTER, SO IM USING ONE OF THE V SHAPED
V-STACKS. I KNOW IT GENERIC,BUT I THOUGHT WHAT THE HECK. DO I
NEED THE STOCK AIR FILTER FOR IT TO RUN RIGHT? I THINK THE GUY
WHO OWNED IT BEFORE ME DIDNT RUN A FILTER AT ALL
THANKS FOR ANY HELP IRONHEAD MYKE
Old Jul 28, 2007 | 09:50 AM
mbogosia's Avatar
Do you have a lid on the airbox? If not you are getting too much air and should be running lean which would cause a white spark plug. Are you familiar with the carb. I am wondering if you removed it and opened it up and sprayed it real good with carb cleaner if that would help. It might be worth a shot. Can of carb cleaner is only a few bucks and it is really good to learn how to remove the carb anyways. Let me know and I'll try to walk you through it.
Old Jul 28, 2007 | 11:40 PM
IVE TAKEN THE CARBS OFF TWICE AND CLEANED THEM, THO I WASNT ABLE TO GET THE SMALL JETS BECAUSE I DIDNT HAVE A SMALL ENOUGH SCREWDRIVER, SO I SPRAYED A LOT OF CARB CLEANER, AND TRIED TO BLOW THEM OUT WITH A COMPRESSER. MAYBE ILL HAVE TO TRY IT AGAIN, WHAT CAN IT HURT,
CAN A BAD SWITCH CAUSE THE BIKE TO START BUT NOT REV? CLUTCH SWITCH IS GONE, NUTERAL SWITCH,REVERSE SWITCH ARE STILL THERE ,I THINK, OR THE STARTING SWITCH CUT OFF RELAY?
WHAT YOU THINK BRO
THANKS FOR THE HELP, KEEP IN TOUCH, ILL GET THIS THING FIXED
IRONHEAD MYKE
Old Jul 29, 2007 | 07:44 AM
tjm52's Avatar
The most common problems with a warrior
Parking brake switch
Stator is dead or weak
Intake boot is cracked or split
Old Jul 30, 2007 | 12:23 AM
txsatm's Avatar
I have a 2000 warrior haveing same type of problems. I have cleaned the carb checkind Intake boot changed plug.... Same thing idle is perfect hit the gas stalls out?? Even in neutral?? Any ideas? (Also checked timing... perfect). Thanks in Advance!
Old Jul 30, 2007 | 08:31 PM
bberck's Avatar
Like tjm52 the intake boot being cracked or split is very common. Alot of times it is hard to see the split with out taking it off and giving it a good look over.
I had a old big bear 350 that was doing the same thing. The intake boot seemed to be fine but when I removed it and bent it I found the crack.
Old Jul 31, 2007 | 04:57 PM
CAN THE INTAKE BOOT BE CRACKED AND IT MIGHT START UP AND RUN
6-8 TIMES BEFORE IT WILL TAKE A CRAP, THEN STARUP AGAIN, JUSTA OUT OF THE BLUE, THEN SAME OL SAME OL, JUST STOP RUNNING? ALSO, IVE REMOVED ALL OF THE PARKING BREAK STUFF,SWITCH ON THE BARS, AND THE PARKING BRAKE OFF THE REAR BRAKE, NOW, IS THERE ANY WIRING THAT HAS TO BE REMOVED ALSO? A RELAY OR SOMETHING. I HAVE NO BATTERY OR SIMILER STUFF ON THE BIKE, CAN IT BE SOMETHING IN THE WIRING OR A REALY?
THANKS LOADS IRONHEAD MYKE
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Steeldon
Sep 8, 2015 10:51 AM
