Redcat 110 crank assenbly
Old Jul 30, 2007 | 09:38 AM
benhurmx's Avatar
Default Redcat 110 crank assenbly
Hi,
A couple of weeks ago my daughter's atv started to have some problems, The motor started fine but it had difficulty to move. So i tried to adjust the clutch, though it did a tiny improvement the problem was still there. So i figured it was time to change the clutch since we used the ATV for 2 years without major problem. I ordered a new clutch and special socket to take it apart. To my surprise when i removed the cover i found out that the tip of the crank shaft was broken ( twisted). Now is it better to change the crank assembly or buy a new whole motor. How difficult it is to split the cases ? Any place to buy reasonable priced parts ? Is the Honda atc 110 crank assembly compatible with the Red cat ?
Thanks
Old Jul 30, 2007 | 11:26 AM
billl2099's Avatar
redcatmotors has the crankshaft in stock at $40.99 part no. 100757 plus don't for get all the gaskets, head, cylinder,center crankcase, right crankcase, valve cover, left cover, while you at it might as well put a new cylinder ($13.99) piston ($26.99) and rings (?) or you could purchase the whole engine at $347.00 ,you can contact redcatmotors at 602 256-2282, this should take somewhere around 4-8 hours to complete depending on your ability.
Old Jul 30, 2007 | 11:35 AM
billl2099's Avatar
also don't forget the crankshaft seals, i almost did. here's another engine to consider from e-bay item no.190134873300 this is for a new fully automatic transmission 110cc for $169 pus shiping of $59. with a 6 month warranty
Old Jul 31, 2007 | 06:30 AM
benhurmx's Avatar
Thanks for your detailed reply. I am going to call them and decide what to do.
Old Jul 31, 2007 | 10:15 AM
billl2099's Avatar
if i had a bad crankshaft on a kids chinese atv, i think i would just buy the e-bay engine for the $169 and be done with it, takes about an hour to replace one of these engines,
Old Jul 31, 2007 | 02:21 PM
anniecn's Avatar
Usually, you ask the sellers' where to get the right spare parts. If imported from China, they will send you the spare parts I think. But maybe will charge you the air freight.
pgamboa
Dec 24, 2023 11:52 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
QuadRiders
Oct 22, 2015 04:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
