Twist and thumb throttle in one
Old Aug 5, 2007 | 07:14 PM
lhamagedon's Avatar
Default Twist and thumb throttle in one
I just ordered a Terrycable dual Gasser throttle.
The info:
This is a high performance thumb and twist throttle for your quad / ATV. It is made from aircraft grade billet aluminum. Has a switch to enable use of the thumb throttle option or the twist throttle option. Thumb and Twist work at the same time or push a button and lock the twist for thumb only.
Anyway, does anyone know if the stock cable will work with it? or where do I get one that will?
Also I will be using a TM45 carburetor.
Thanks.
Old Aug 5, 2007 | 08:01 PM
lhamagedon's Avatar
Here it is terrycable.com
Old Aug 6, 2007 | 05:24 PM
lhamagedon's Avatar
Well I guess no one knows the answer.
I ended up ordering a custom cable from Terrycable to go from the Dual Gasser to the TM45.
it was $35.
Pehter
Oct 3, 2024 11:00 PM
hueby
Nov 6, 2015 11:34 AM
wrencher82
Sep 28, 2015 10:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
89Lt250r
Sep 7, 2015 07:53 PM
