warrior
Old Aug 6, 2007 | 06:39 PM
tony yaho's Avatar
Default warrior
This guy want to sell me his warrior but it has to be pop started everytime. He said he lost the key so he took apart the key switch and hardwired it. It has no kick start. Woulden't all I have to do is just buy a new key switch, or do you think something else could be wrong? Please let me know.
Old Aug 6, 2007 | 06:46 PM
rruser's Avatar
Default warrior
Well, the keyswitch just turns the power on for everything. Once the power is on the starter button should work. You could try to jump start it with a car. If that doesn't work there are a few things that could be wrong. The starter itself, the solenoid or maybe a safety switch.
Old Aug 6, 2007 | 06:51 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default warrior
depending what year it is i have a keyswitch i'll hook ya up with.. being bump started isn't bad for it..
Old Aug 6, 2007 | 06:59 PM
tony yaho's Avatar
Default warrior
Its a 2001. I don't want to bump start it everytime. Even if its wired to run without a key, souldn't I just be able to put in on run and push the start button? Also what is a cdi ignition? Does that have anyting to do with this problem?
Old Aug 6, 2007 | 07:02 PM
Speedy2222's Avatar
Default warrior
no the problem is when you leave the key on it drains the battery
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
