I need Master Cylinder help
Old Aug 7, 2007 | 04:38 PM
LyleStyle's Avatar
Default I need Master Cylinder help
I have a 1999 honda fourtrax trx 300 and I am having a real problem getting the front brakes to work. I just recently bought this ATV and the front bakes were not working. There are no leaks in the system and I put on new pads. I have tried many different methods of bleeding them now for over a month. So I decided to buy a master cylinder rebuild kit. I was wondering if someone could tell me were and what direction the rubber washers face. Thanks.
Old Aug 7, 2007 | 08:00 PM
HondaMechanic's Avatar
Do you mean the 2 cups ..
Old Aug 9, 2007 | 08:55 AM
HondaTechnician's Avatar
Im only guessing, but those have to be manually adjusted, and I am willing to bet thats your problem, adjust the brakes before you dis-assemble the master cylinder.
Old Aug 9, 2007 | 07:58 PM
LyleStyle's Avatar
Ok I went out there last night and I adjusted both sides of the brakes until I could fell and hear them rubbing. I could still turn them. Still nothing.
So then I took off the drum and removed both brake pads. I then started pumping the master cylinder and the calibor moved and keep moving out until they popped out. So I put them back in, put everything back together, bleed them. and Still nothing.
It acts like it will not build pressure. So thats why I thought maybe it was the master cylinder. One of my problems is, I cant remember where and which direction to face the rubber cups (picture above). I think I know where the back one is suppose to go but its the front one that I'm unsure about. Does the front rubber cup go on the very end and the spring goes on top of the rubber cup or does it go on the next slot on the little piston piece and which way do I face it? I think I might have all that wrong.
Old Aug 9, 2007 | 08:34 PM
Try using needle nose visegrips and pinching the rubber hose about 1-2 inches from the banjo bolt .. Then pump the brake lever and crack the banjo bolt a few times to let any air out ..
Old Aug 13, 2007 | 06:34 PM
LyleStyle's Avatar
I'm still needing to find out which way the rubber cups need to be facing on the little piston piece though? Anybody know?
Old Aug 13, 2007 | 10:35 PM
Like this .. If you look close in the orginal picture you can see..
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
