400ex wont start
Old Aug 13, 2007 | 03:03 AM
yankees12's Avatar
Default 400ex wont start
Hey Guys I am new to this forum and wanted to help my friend get his Honda 400ex back working. I do not have a quad and dont have much knowledge on them, but I will explain to you the problem. Okay When my friend is starting his 400ex, you know turn the key on and when he presss the electric start the electric start does not crank over trying to start the engine. We tried roll starting it and that also did not start the engine. My friend's dad think its the spark plug, but wouldnt the electric starter crank even if the spark plug was bad?? Do you guys think it might be a combination of a bad Battery and spark plug?? When looking at his quad I found the yellow seemed to be spark plug off the quad just dangling there. I asked him and he says his dad disconnected it, but when we press the electric starter shouklldnt the spark plug ignite and burn red??? I have very little knowledge on quads but do you guys think this problem is due to a battery?spark plug issue? I asked around at Pbnation and one suggested to take it to a shop, but its not my quad so I can't. Is this an easy fix or something alot worse? Thanks a ton, Chris
Old Aug 13, 2007 | 07:56 AM
HondaMechanic's Avatar
Yes the bike should turn over even if is has no fire or the spark plug is bad ..The bike won't turn over/start unless it is in neutral & the kill switch on , but I'm sure your buddy knows how to start his bike ... Do you have a volt/ohm meter to check the electric system..?.
The spark plug is hard to change on the 400EX without the spark plug wrench in the tool kit ..
Old Aug 13, 2007 | 11:48 AM
yankees12's Avatar
Yes I believe I have a volt meter if not I will buy one, but what should I check for in the system such as the battery? Also The yellow spark plug was off dangling infront of the motor, I dont know how my friend's dad did it but it was off. I think it is the battery it has to be or something deeper in the electrical system, but HOndaMechanic what should I check with the Volt Meter??
Old Aug 13, 2007 | 01:40 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
First thing that comes to mind is a blown fuse. Do the headlights work??? The headlights and starter are on the fused circuit.
Even with a blown fuse, it should push start! Be sure you have the key on and the kill switch is on, when you push start.
Old Aug 13, 2007 | 03:45 PM
Yes ..Check battery voltage , I believe there is only 1 fuse 15a , power at solenoid .. What is your email address and I will email you a couple of sections from the TRX400EX PDF shop manual ...
Old Aug 13, 2007 | 05:33 PM
yankees12's Avatar
my email is cmarthers12@yahoo.com, I will se if the headlights work but I believe they do. Also how do you connect the spark plug so we can try push starting the quad just to see if its an old battery?? THanks for all you guys help
Old Aug 14, 2007 | 01:57 AM
Dillpick351's Avatar
what i had to do with my trx 250ex is pull the seat off and where the wires go from the battery to the starter touch a screwdriver or a wrench to both and it should make a power transfer through the wrench or screwdriver and will tell you if its the battery or not and dont be afraid it will nor shock you it might spark once but it should start
Old Aug 14, 2007 | 01:07 PM
POlsen's Avatar
does it have any compression?
DTroyer01
Jul 3, 2015 07:34 AM
Bm400ex
Jun 22, 2015 09:16 AM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
jbertch
Nov 6, 1999 07:07 PM
