300 trx wont start
Old Aug 15, 2007 | 04:53 PM
handadm's Avatar
Default 300 trx wont start
My sons 2002 wont start, new batt. no lights come on when you turn key on.
Old Aug 15, 2007 | 09:27 PM
handadm's Avatar
may be it ex not sure but still wont start or crank over,
no one has ideas?????
Old Aug 15, 2007 | 11:07 PM
HondaMechanic's Avatar
You will have to test the ignition system .. If you know what year/model I can email you shop manual tests ..
Old Aug 15, 2007 | 11:13 PM
handadm's Avatar
thank you it is trx300ex 2002
Old Aug 16, 2007 | 08:11 AM
Post or PM your email address..
Old Aug 20, 2007 | 06:40 PM
93EX's Avatar
i have had the same problem with my 93 ex. when i ride in the mud dirt gets lodged inbetween the battery cables. unscrew the cables off the battery and clean the cables and the battery off with a rag to get any dirt or mud off. it should run after this. i have to clean mine out all the time.
Old Aug 20, 2007 | 11:15 PM
handadm's Avatar
Thank you 93ex.
but i put new batt, in and nothing
I can put jumper wire aross and it will crank that way, but no spark or lights nutral light nither
Old Aug 21, 2007 | 07:40 PM
93EX's Avatar
maybe something got disconnected? sry it didnt work for you. good luck!!
Old Aug 22, 2007 | 09:01 AM
HondaTechnician's Avatar
The very first thing I would do, is have a look up at the handlebars where the ignition switch plugs into the harness, if that comes loose, it will cause the problem you discribe. If they are plugged in properly, and you suspect the ignition switch of being bad you can unplug the switch, and then take the two wires of the harness, just plug them into each other and see if that makes it work, if it does, its a bad switch.
Old Aug 22, 2007 | 06:03 PM
handadm's Avatar
thank you handa tec.
I done that already and still nothing, handa mec. sent me part of shop man. but have not had time to get into the barn
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
