Honda ATC 110 help needed
I got myself into this 3 wheeler, and it's a mess. Any owner manual dl's? Pics of what it should looklike? I'm a 8 cyl motor head, and I have no idea what I got. Tomorrow the shifter is welded on, (splines are screwed). Clutchless? What is the left hand lever for? This is not a joke, it just doesn't make sense.
DevourU
DevourU
BTW, it starts, and runs, stalls at idle. Timing cover and air filter are missing. Parts source? There is a gear selector above the foot shifter that puts the tranny in gear that is not connected to anything. Wassup? Thankx for any help.
DevourU
DevourU
Its auto-clutch. Left hand lever should be front brake. I know that there is a hi/lo gear selector low behind the left foot peg. Not sure if that is what you are talking about that is not connected to anything. If so do you mean that the hi/lo gears are missing? Pull the carb and give it a good cleaning, make sure you check and clean the fuel filter that is built into the carb also. Go down and purchase a manual for it from your local bike shop. Try checking out rockymountainatv.com or ebaymotors.com for parts.
:Not a problem I got into the same boat a couple years ago
Being a V8 nut
Just relax it is all the same just on a smaller scale 1cyl
First pickup a manual figure out what year the trike is
The brake lever on the left is for the rear brake also attached to the foot brake
If a 110 you will only have rear brakes
If you have front brakes then you probably have a 125 or some one changed forks and added
shifter on this you will have the foot shift it seems yours is welded OK
the lever under back of trans is Hi-Lo it is adual range transmission
The other part you are refering to is the shift indicator should be a white collar with red pionter tells you when in Neutral
All the way up on shifter is neutral shift to higher gear push down 3 speeds
engine runs no idle check fuel filter this is where the manual comes in handy
get manual follow setup basics it is simple
begin check timing should be electronic ign
Timing can be set with automotive timing light Inductive and connect timing light pickup to number 1 plug wire since only 1 cyl that is #1 connect power leads to 12v battery start check timing simple
then check carb adjust set idle
Like I stated early on in same boat now my buddys bring me their bikes to fix same but smaller scale little changes big difference go slow they are simple
good luck
Ride safe
Ray
Being a V8 nut
good luck
Ride safe
Ray
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
