exhaust wrap
Old Aug 29, 2007 | 07:34 PM
embler's Avatar
Default exhaust wrap
anybody here ever use exhaust wrap on their atv? I've used it before on my race cars with good results. it'll keep the heat in the exhaust for better flow and also my leg won't miss the heat. what's everybody's opinion on it?
Old Aug 30, 2007 | 03:30 PM
sheepdogMSP8117's Avatar
A few guys are using it. I'm about the wrap my exhaust on my new 800 as the right side gets fairly hot.
Old Aug 30, 2007 | 03:50 PM
dwhst9's Avatar
Wrapping the exhaust (and headers by the way) will eventually rust the exhaust out.
Old Aug 30, 2007 | 03:59 PM
embler's Avatar
when I wrap mine I'm gonna clean it off with a wire brush first and hit it with a few coats of high temp paint before I wrap it. I can't see how it'll rust out any faster than it would if it was exposed. the wrap actually will be a barrier for any moisture and any moisture that does get past it will be burned off by the heat. I wrapped some headers on my car and the wrap stayed on for 2 years before I took it off to put on some long tubes. they still looked the same as the day I wrapped 'em.
Old Aug 30, 2007 | 09:55 PM
SPORTSMAN70003's Avatar
Take my advise and save your money and do the ceramic coating. I done the exhaust wrap from DEI with the exhaust HI Temp DEI coating and just washing my 700 twice I already had rust forming on the pipes. I also wire brushed and spray HI Temp paint on before applying the wrap. The reason I took the wrap off was because I didn't wrap my turbo and all the heat was staying in the pipe and when the heat made its way back to the turbo it was causing the turbo to get really hot. So I decided to take the wrap off and ceramic coat my pipes and turbo and thats when I found the rust.
Old Aug 31, 2007 | 12:41 AM
XavierOnasis's Avatar
I've been using the wrap, and I'm very pleased. The thought of promoting rust never occurred to me.
Old Sep 6, 2007 | 01:28 AM
jtlongfellow's Avatar
What does the ceramic coating look like on the pipe and where would you get it done?
Old Sep 6, 2007 | 09:26 PM
RticKwad's Avatar
Runs Stealth!
JT -
Ditto!
R'
Old Sep 6, 2007 | 10:14 PM
I got mine done locally. You can go to http://www.jet-hot.com and see some pipes there.
Old Sep 6, 2007 | 10:25 PM
sparks1032's Avatar
not sure how well the ceramic coating will reduce the heat? the wrap has always been suspected in making pipes rust faster but its like opinions use it and save yourself a lot of down time sending that into jet hot!
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
