660 craptor carb problems?
Old Aug 29, 2007 | 08:09 PM
bombrider04's Avatar
Default 660 craptor carb problems?
I know this is the bomb forum, but you guys will help me out...I have a 660 raptor that is my buddy's and it will work wen the choke is on and when I give it gas it will cut out...I cleaned it and the diaphragms are good...If I held my hand over the intake just a little it would run better so what I have established from messing with it a while longer...It was runnign while I cut off air because only one carb actually is working and the 2nd isn't getting any fuel so I blew air through the best that I could and put it back on and the same thing is still happening...Do you think I should get them rebuilt, get a single carb or what...The passage from carb to carb is fine and the 1st carb is fine where the inlet for the gas comes in it's the 2nd that isn't working...thanks
Old Aug 29, 2007 | 08:10 PM
http://216.37.204.206/alba/Yam...sp?Type=13&A=292&B=11
this is what they look like
Old Aug 30, 2007 | 02:47 AM
DuneMe's Avatar
Those carbs are absolute junk and the reason I SOLD my Wife's old Raptor
Lose the carbs and go to something else. They are nothing but frustration!!!
I love the FCR carbs but, I would go with a Lectron or Edelbrock too.
Old Aug 30, 2007 | 10:17 AM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Well I guess it depends on how much money you have :0) I have a 01 Raptor and my carbs work fine if I were you I would gut the carbs and buy some carb dip and dip them over night and then blow them out then replace the needle and seats to the floats and then check it again it sounds like your buddy let it sit and something got gummed up and plugged. If you have the money then go buy an aftermarket carb they are much better if you are going to pump up the motor.
Old Aug 30, 2007 | 02:58 PM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
Check the wire for the reverse if it comes off it will do the cut out thing.
Old Aug 30, 2007 | 09:06 PM
Only one carb is actually spraying any gas though, but that is something to think about, but I told him either get a new carb or take it to the stealer.
Old Aug 30, 2007 | 09:34 PM
Just out of curiosity what does the reverse do that makes them conk out not for his bike, but I just want to know for future reference.
Old Aug 31, 2007 | 10:39 AM
Tpsycho's Avatar
It is a TORS system Throttle override system what it does is limits the RPM your motor can put out and retards the timing electronicley. The first thing I take off of a yamaha is the system on the emergency brake and the carbs on the banshee they are a pain in the but.
Old Aug 31, 2007 | 04:24 PM
Got ya I was just curious to find out thanks for the info...Yea I found out how junky the carbs actually are the other day trying to mess with the darn thing.
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
