02 Sportsman 700
Old Aug 31, 2007 | 04:29 PM
Cmitchell79's Avatar
Default 02 Sportsman 700
I have a 02 Sportsman 700 that is sputtering when ever I go across an off camber to the left. If I feather the throttle I can keep it running, but if not it will die. It runs perfect other than that. It has been doing this for a while so it has had many tank of gas run through since I first noticed the problem. I have changed the fuel filters and cleaned the carb. Any ideas what might be happening?
Old Aug 31, 2007 | 06:45 PM
dosceola's Avatar
fuel pickup in tank is bad unless its happening with full tank as well. only other thing i can think is floats in carb needed to be replaced, needles may be bad in carb. but its in carb for sure
Old Aug 31, 2007 | 10:12 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i agree w/ it might be the float.
Old Aug 31, 2007 | 10:55 PM
SPORTSMAN70003's Avatar
Yeah sounds like you float might be set a little high. Does it puff any black smoke when this happens?
Old Aug 31, 2007 | 11:57 PM
It sputters now matter how much gas is in it. I don't notice any smoke. I guess it is time to get the carb off again and get it rebuilt.
Old Sep 1, 2007 | 12:01 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if it runs fine on the flat it doesnt need to be rebuilt just adjust the float level should take care of it.
Old Sep 2, 2007 | 01:10 AM
Thank you
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
