TB tranny
Old Sep 3, 2007 | 12:42 PM
kthrift's Avatar
Default TB tranny
Need to replace the tranny on my 01 TB 250. Anybody know which trannys it will accept?
Old Sep 3, 2007 | 08:19 PM
ftwflh's Avatar
Default TB tranny
2000-up 250 trailblazers and 325 trailboss and 330 trailboss.What is wrong with your tranny?
Old Sep 3, 2007 | 09:49 PM
dealseaker's Avatar
Default TB tranny
yea, whats wrong with it, whats it doing wrong?
Old Sep 4, 2007 | 07:50 PM
kthrift's Avatar
Default TB tranny
On acceleration from a stop or slow speed I hear a loud clunking from the tranny. I ruled out the sprockets. All teeth present and sharp. I figger it would be easier to drop in a used one than to break it down and hunt for the source.
Any ideas?
Old Sep 4, 2007 | 09:03 PM
dago-fast's Avatar
Default TB tranny
I have an 05 trailblazer that made a noise when going forward. It was like a clicking noise. Turned out my chain was loose and rubbing on my chain guide.
Old Sep 4, 2007 | 10:23 PM
ftwflh's Avatar
Default TB tranny
If your drive chain isnt jumping the sprocket the silent chain inside the tranny is stretched.Not hard to replace if you have a manual.
Takes more to pull it out than to fix the tranny.
Old Sep 5, 2007 | 09:26 AM
kthrift's Avatar
Default TB tranny
Can the silent chain be replaced with the trans still on the quad?
Old Sep 5, 2007 | 12:28 PM
ftwflh's Avatar
Default TB tranny
<div class="FTQUOTE"><begin quote>Originally posted by: kthrift
Can the silent chain be replaced with the trans still on the quad?</end quote></div>
you have to pull the tranny out of the frame to split the cases.
Old Sep 17, 2007 | 07:23 PM
kthrift's Avatar
Default TB tranny
I have the tranny loose but it still has one connection I cant identify. Does the tranny attach to the swingarm pivot bolt on the left side? That is where the hangup seems to be. Also, I found metal shavings on the end of the magnetic drain plug bolt/spacer so I was relieved a little to know that I made the right choice in pulling the trans. However, metal shavings in the trans is NEVER good.
Old Sep 17, 2007 | 10:46 PM
ftwflh's Avatar
Default TB tranny
I dont pull the swingarm bolts to get them out.But you do have to remove one of the bolts that runs through the tranny.
The filings are normal.Once you get into it you will see how simple this thing is.
Logan Collins
Sep 5, 2015 08:03 PM
Haakon
Aug 24, 2015 01:54 PM
DOAinNY
Jun 12, 2015 02:26 PM
mpcop077
Jun 10, 2015 08:30 PM
