trx250r caliper rebuilding
Old Nov 26, 1999 | 02:52 PM
fast-track-matt's Avatar
having problems with trying to rebuild my calipers. [ seal replacement/ on both front and rear.] following my service manual, ive been blowing air in the inlet of each caliper and only one piston comes out.... I can not seem to get the other piston to come out as well.... [ all 3 calipers are doing this?????
anybody have any secrets they can give me?? thanx.......
Old Nov 26, 1999 | 04:41 PM
bpace's Avatar
What you need to do is place a small piece of wood or steel(I use a 12" ruler) inside the caliper as though it was a brake pad. This will act as a stopper strip. Now apply pressure to the line connection. One piston will start to come out until it hits the stopper strip then the other will come out. The trick is you don't want to initially blow the one piston all the way out. Using a stopper strip will prevent this. After both pistons are out againts stopper strip, remove stopper strip and blow them the rest of the way out. You may still have to pull one of the pistons out with your fingers but this shouldn't be a problem now.
Old Nov 30, 1999 | 12:08 PM
general2's Avatar
I have been having lot's of trouble with my 86R. I cannott seem to get the pin out of the caliper. Does anyone know how to get it out? I have tried heating it up and still no luck.... The pin is the one that lets the caliper move freely over the disc. Right now the pin does not move and then makes the caliper pin itself against the disc.
Any suggestions?
Old Nov 30, 1999 | 01:07 PM
Witz's Avatar
I had the same problem with both of my 250Rs, and both required a great deal of heat to get the pins out. Try soaking the pin in something like Liquid Wrench or PB Blaster for a few days to loosen up the corrosion and then try heating it again. This worked for me on my '87, but my '88 was so bad I ended up giving it to someone with an acetylene torch in order to heat it up enough. Hope this helps.
Old Dec 2, 1999 | 01:40 PM
Lightninn's Avatar
Acccck!! You're scaring me, Witz! I have an 88 and haven't had to work on the brakes (yet)... Now I'm NOT looking forward to it.
Lightninn
Old Dec 6, 1999 | 05:05 PM
WAYMOD's Avatar
Please everyone use alot of Anti cease (that real messy silver stuff) You won't ever have these problems again. It works especially well where steel touches aluminium and corrosion is formed.
I use it on my swing arm bolt, rear and front brake bolts, hubs, axle nut, motor mount bolts etc etc.. I think you get the idea, use it everywhere.
Waymod
Beeline08
Nov 11, 2016 04:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
snowolson
Aug 31, 2015 03:51 PM
