Brakes not working
Old Sep 5, 2007 | 11:58 PM
robc's Avatar
Default Brakes not working
Help, I pulled the calipers and stripped them down, cleaned the grime off of them. I put everything back together and the same thing happens. You have to pump the brake handle to get the fron brakes to work and then they stay closed for a period of time before slowly working themsleves back out. Replaced with fresh brake fluid and bleed the air out of the line. Any help appreciated.
Old Sep 6, 2007 | 12:54 AM
03scrambler500's Avatar
it sounds like the seals in the master cylinder are shot
Old Sep 6, 2007 | 08:49 AM
robc's Avatar
Is the MC the box at the top by the brake lever? Would the seals be the rubber gasket on the lid or something else?
Old Sep 6, 2007 | 09:03 AM
yeah thats the master cylinder and there is an internal piston and seals that if are shot won't pick up the brake fluid and then as your trying to compress it it all leaks by. it is some times hard to get all of the air out of the lines but the way that your describing it seems like it is a shot master cylinder
Old Sep 6, 2007 | 09:11 AM
robc's Avatar
Something thats hard to rebuild or is it worth it. Or jus replace the entire unit?
Old Sep 6, 2007 | 09:12 AM
i don't think there is a rebuild kit i'm not sure though good luck!
Old Sep 6, 2007 | 09:13 AM
robc's Avatar
10-4, THanks for the info.
Old Sep 6, 2007 | 09:18 AM
scootergptx's Avatar
Supersock
Hired Gun!
The master cylinder isn't cheap though.
Got lucky and found a good one on ebay, otherwise it was 150 bucks from the dealer.
Reactant
Mar 30, 2022 02:08 AM
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
