Polaris 500 overheating.
Old Sep 6, 2007 | 06:21 PM
magals's Avatar
Default Polaris 500 overheating.
I took my 500 sportsman out yeaterday for a ride and it overheated on me. I never heard the fan kick on. Anyone have any suggestions as to what could be causing the fan not to kick on. Any info. would be helpful thanks.
Old Sep 6, 2007 | 06:25 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Try to give it a little spin......Some on here before said the sticks and mud can make the fan stick.......................So they gave it a little turn and away it started!!!...........But it may need to be replaced...........If it don't start on it's own...................
If that don't work.................Try given 12 volts directly to the fan and see if it comes on.............Caper..................
Old Sep 6, 2007 | 10:13 PM
jodaanja's Avatar
I'm betting it's the little thermostatic switch that controls the fan. It is located in the top corner of the back of the radiator. I had one go bad on my '00 Magnum 500. It's an easy fix.
Old Sep 6, 2007 | 10:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
try unhooking the plug on the sensor after checking the fan for free spinning (w/ the key off) and to make sure its free. if the fan works it should come on when the plug is unhooked w/ the key on. just to rule out the fan. make sure the rad. is clean also.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
