Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Clutch theory
Old Sep 11, 2007 | 09:56 PM
nuke's Avatar
Default Clutch theory
Can a "wrench" out there explain how ATV clutches function, and the differences between brands? Yamaha touts their "constant tension belt." Does Yamaha have an internal wet clutch? How about Arctic Cat, is it also a constant tension belt? An Arctic Cat shop manager referred to "rollers" that require occasional maintenance, so this sure doesn't sound like an internal wet clutch, or is he referring to the variable-width pulley mechanism? Have never owned a belt-drive machine, but about ready to purchase, probably between a Rhino or Prowler. Opinions? Which is more reliable? Looking for a machine whereas one does not have to keep the revs up at low speeds.
Old Sep 20, 2007 | 07:42 PM
AZ Jeff's Avatar
The Arctic Cat clutch system consists of a centrifugal clutch (located on the output shaft of the engine) coupled to the belt drive CVT (continuously variable transmission). The clutch is actually inside the engine case, behind the compartment that houses the belt pulleys. The belt itself rides on a spring loaded driven pulley and a flyweight controlled driving pulley.
Old Sep 20, 2007 | 08:04 PM
nuke's Avatar
Jeff, can't thank you enough! Is it a wet clutch as Honda and possibly others use? If this is the situation, I am leaning towards Arctic Cat for a SxS when the EFI model arrives. Correct me if I am wrong, but Polaris uses the belt for a clutch? How about Yamaha, a wet clutch?
Old Sep 21, 2007 | 11:48 AM
AZ Jeff's Avatar
Yes, the AC clutch is a "wet" type, and is exposed to engine oil.
The Polaris system relies on the belt to be the clutching device, and seems to work equally well. It certainly contains less parts in total.
I cannot speak for the Yamaha clutch system, as I have never seen one of them taken apart.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
