2003 Sportsman 600 front end engagement
Old Sep 26, 2007 | 01:04 PM
minkman's Avatar
Default 2003 Sportsman 600 front end engagement
[img]i/expressions/beer.gif[/img]
I recently aquired a 2003 Polaris Sportsman 600 and the front end will not engage in either Low or high AWD with the rear end jacked up and free from the ground. The AWD indicator lights up and the switch appears to be OK. However the front end will engage in reverse with the Yellow reverse override switch depressed. I suspect an electrical problem, but don't know where to look. Any help will be greatly appreciated. Thank you. laskeno7@msn.com
Old Sep 26, 2007 | 02:59 PM
hobbles's Avatar
Afternoon minkman
I'm not sure bout the 03 models if they have the Hilliard front trans., I know with my 06 500 X-2 the back wheels have to turn/slip 1/5 of a turn to engage. And when they do engage I can't feel it, It's just there, As for holding the yellow button in, in reverse, That over rides everything and is in 4wd,
Old Sep 27, 2007 | 03:24 AM
dosceola's Avatar
if u have a pod u should have diagnostic mode to check switch. should engage if reverse goes in but sounds electrical is fluid good in front diff?
Old Sep 27, 2007 | 08:45 AM
minkman's Avatar
I checked the AWD switch and it is working along with indicator LED. And I just changed the front and rear gearboxes with Polaris synthetic lube along with the transmision with Polaris synthetic lube. A local Polaris dealer told me to check the transmission gear selector switch on the side of the transmission, but without a electrical schematic I have no clue what to check. I was told there is about a 20 step process to check the electrical system as the speedometer is suppose to be part of the AWD engagement. Thanks for all your help.
jayking232003
Dec 4, 2019 09:38 AM
neilbedwell
Nov 10, 2018 11:02 AM
3quadbob
Sep 18, 2016 09:46 PM
Rooky
10
Jun 23, 2015 09:35 PM
yellowpolaris
Jun 21, 2015 11:13 AM
