Need torque for 07 YZF450 nut on bottom of steering column.
Old Sep 26, 2007 | 07:46 PM
YamahaPolarisOwner's Avatar
Default Need torque for 07 YZF450 nut on bottom of steering column.
We had to change out the steering column for a 07 YZF450 SE after flipping it climbing a steep hill. The stock Pro Taper handle bars were fine, but the steering column was badly bent.
We have the new one, but the bottom nut was really tight to break loose off the original.
Does it require Loctite and what is the torque?
Brand new to the site and thanks or the help!
Old Sep 26, 2007 | 09:05 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
i beleive it has a cotter key,if it does then get it snug with a wrench then give it a couple good grunts and put the key in it, if it doesn't i'd use some blue loctite
Old Sep 27, 2007 | 01:02 PM
give me a break 's Avatar
the tourqe setting for that nut is a big number N.m at 110 or ft-lb.81 this is the setting off my 05 raptor but it will do for the yfz no problem
Old Sep 29, 2007 | 02:49 PM
Thanks for the info!
Old Sep 29, 2007 | 04:55 PM
STRAIGHTUPDAHILL's Avatar
GOOD N TITE
dannytas
Sep 26, 2017 06:31 PM
badgerboy1
Sep 26, 2017 06:11 PM
Beeline08
Nov 11, 2016 04:00 PM
Sep 30, 2015 01:37 AM
2many2ride
Sep 27, 2015 04:35 AM
