HandleBar Questions
Old Sep 28, 2007 | 08:25 PM
ds650atv's Avatar
Default HandleBar Questions
Hi Guys, have a couple of questions regarding Handlebars.
First I am looking to get some taller handlebars. I am a tall guy 6'4" and i'm looking for more comfort and also to add the dashboard to a trailtech vapor I recently purchased. Not sure what bend I should go with on the handlebars.
Second, Do any of you use the handlebar anti vibration inserts? Do they really work? I have an 05 ds with the hand guards that screw into the side of the grips and i'm not sure how the inserts would work. But wanted to get your opinion if they actually work or not.
Thanks.
Old Sep 29, 2007 | 12:25 PM
cynick's Avatar
Default HandleBar Vibration
I don't run the vibration dampeners, but I do run taller bars. Right now I'm currently running a set of MSR Dominators in ATV high bend, I'm 6' 2" and they feel fine, plus the crossbar is high enough to put your Trailtech on and still be able to see it.
Old Oct 2, 2007 | 04:50 PM
ds650atv's Avatar
Thanks for the info Cynick.
Anyone else run taller bars? If so what setup are you using?
Old Oct 2, 2007 | 05:56 PM
BioWare's Avatar
Toxic Ryder
I have some Pro Taper Bars and they are a Mid range I use a Riser to lift them up more. I also bought a trailtech you can see in my pic's where it is mounted off the bars.
Old Oct 2, 2007 | 11:23 PM
Raptereator's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img]Seth are you still going to little sahara in UT?This is chuck ill be there on friday by noon.Any questions call me 801-731-8847
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
