Bear Tracker Flooding
Old Oct 1, 2007 | 12:11 AM
jricard's Avatar
Default Bear Tracker Flooding
My Yamaha 250 Bear Tracker on start up runs for about a minute and then starts to flood and gas goes into the air box from the breather tube. I Removed the carb cleaned, and replaced the needle valve. Still flooding, HELP!
Old Oct 1, 2007 | 01:59 AM
fishguy's Avatar
I'm having the same problem, I couldn't believe how much gas spills out into the air box! I was told it may be that the float in the carb. I will let you know what I found out.
Old Oct 1, 2007 | 07:49 AM
ctateusa1's Avatar
definetly check out the float and see if it is fuel logged
Old May 13, 2024 | 10:41 AM
Justincase89's Avatar
I'm having the same issue if send like the gas doesn't turn off when I turn it off and floods the carb
Old May 14, 2024 | 02:16 AM
It has to be the float needle or a holed float. Dirt in the fuel will cause it to do this, as will a faulty float needle. However if "the gas doesn't turn off when I turn it off" your fuel tap has a problem too, so fix that first. Also fuel should run out of the overflow at the bottom of the float chamber if the needle sticks, previous posters seem to have had it running into the airbox, the overflow pipe must be blocked, or raised above float bowl level for that to happen.
searstj22
Aug 23, 2018 02:57 AM
jsteffen
Jul 12, 2018 11:52 AM
sburcham
Oct 17, 2012 10:33 AM
gbarry
Sep 1, 2009 12:19 AM
JGreenz24
Oct 31, 2005 08:41 PM
