Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
NEEDING 350 WARRIOR EXPERT
Old Oct 2, 2007 | 11:44 AM
ROB RAY's Avatar
Default NEEDING 350 WARRIOR EXPERT
MY 10 YR OLD SON HAS A YAMAHA WARRIOR 350 // SEEMS MOST TIMES OUT OF TEN WE HAVE TO JUMP START THE BIKE TO GET IT TO FIRE. FOLLOWING THE JUMP IT CAN BE RIDEN, TURNED OFF AND ON FOR SOME TIME. AFTER SETTING HRS OR THROUGH THE NIGHT IT WILL AGAIN REQUIRE A JUMP. OF COURSE A NEW BATT HAS BEEN PUT ON IT. SOME TELL ME THE RECTIFIRE IS WHAT CHARGES THE BATT OTHERS TELL ME IT THE STATOR. COULD SOMEONE PLEASE ADVICE ME. I DO APPRECIATE YOUR TIME. (ROB IN PB, MO.)
Old Oct 5, 2007 | 11:45 PM
ghcoe's Avatar
Sounds like you have a power drain some where in the system. Try driving the unit around and verify that it starts when you are done riding and then disconnect the battery. When you are ready to ride again, rehook up the battery and see what happens. If it starts right up then you have a drain in the system. Could be a bad diode in the RECTIFIRER. The diodes in the rectifirer convert alternating current (AC) to direct current (DC). If a diode goes out it will allow current to flow back to ground when the motor is shut off. Hope this helps. George.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
jgiljr
Aug 21, 2015 06:15 AM
Mphillips
Jul 2, 2015 07:20 PM
Nelson
Jun 20, 2015 01:59 PM
