03 kodiak shifting problems
Old Oct 6, 2007 | 07:40 PM
millarville92's Avatar
Default 03 kodiak shifting problems
I have a 03 kodia[img]i/expressions/face-icon-small-confused.gif[/img]k that will not go into park . The shifter seems like it will not shift down into that position.Any help would be great ;I hope its just a simple adjustment.Thanks for info.
T
Old Oct 8, 2007 | 04:48 PM
the shifter just will not go down into park..help please
Old Oct 8, 2007 | 04:55 PM
it is a ultramatic /atutomatic not a manual shift.
Old Oct 8, 2007 | 05:58 PM
225dx400kodiak's Avatar
i would disconect the shift rod and try shifting it by hand on the case and on the shifter to see witch area the problem is in if you can shift it on the case then it may be the lock pin on the inside of shifter causing you trouble i removed mine for the same reason the pin is operated by a cable to the foot brake on my 02 if it is not that then you may have to split the engine case hope you are mechanical
lightninboy
May 16, 2021 09:52 PM
RedRancher
Oct 15, 2020 01:45 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
RedRancher
Jul 10, 2015 06:36 PM
