How can I get my atv to start in gear?
Old Oct 8, 2007 | 10:34 AM
blkcloud's Avatar
Default How can I get my atv to start in gear?
I have a 2003 rancher, is there any way I can rig it so it will start in gear? thanks!
Old Oct 8, 2007 | 10:45 AM
tramp's Avatar
ON my 420 rancher, all you have to do is squeeze the hand brake and it will start. You might try that.
Old Oct 8, 2007 | 11:00 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Try searching Rancher, start, neutral, etc. This topic has been posted many times before.
Is it an ES???
Old Oct 8, 2007 | 11:21 AM
blkcloud's Avatar
Yes it is a ES. thanks!
Old Oct 8, 2007 | 11:26 AM
Mountana's Avatar
On my Rubicon, it will only start in gear if you apply the front brake, not the rear. If you want it to start without squeezing the brake, just connect the 2 switch wires on the brake. Make sure you get the right switch and not the brake light switch.
Old Oct 8, 2007 | 11:37 AM
blkcloud's Avatar
where are they located? thanks!
Old Oct 8, 2007 | 11:50 AM
HONDA CRUSHER 93's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Mountana
On my Rubicon, it will only start in gear if you apply the front brake, not the rear. If you want it to start without squeezing the brake, just connect the 2 switch wires on the brake. Make sure you get the right switch and not the brake light switch.</end quote></div>
My cousins Rancher at is the same way. When he first got it it would only start in reverse, but afterhe broke it in it would start in drive.
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Dabears1983
Jun 16, 2015 12:17 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
1000gade
May 27, 2015 12:37 PM
