CHAIN TROUBLE AT MX!
Old Jan 5, 2001 | 09:49 PM
love250x's Avatar
When I go to the track to practice, my chain slowly gets loose.When I give it gas it jerks and won't work proporly,it has a new chain and good sprockets.Feels like the petcock screws are getting loose but they don't.Carrier does not move so I am clueless.Please help!Also what are the most important things I can do for my 250X to get ready for MX(stock but for nerfs).Thanks
Old Jan 8, 2001 | 07:21 PM
brokenmetl's Avatar
my 250X did samething and finally flew of and cracked my case cover. You said your carrier is not moveing but that is usually the culprt. mark on the swingarm and on the chain adjuster then ride real hard about three laps and check. if thasts not it check for worn swingarm bearings
Old Jan 9, 2001 | 04:06 PM
quad040's Avatar
i would say it has to be the carrier, to be sure set up your chain and then take a yellow crayon and make a mark on the carrier and then right next to that mark make another on the swingarm.go ride and then check to see if the makes are not in line
quad040
Old Jan 9, 2001 | 04:45 PM
ModdedX's Avatar
CHeck the carrier like the above said and also check to see if you engine mounts are tight and your swingarm mounts....
As for mods:
Wider a-arms/axle
tires
engine mods(bore, stroke, cam, headwork)
pipe
Handlebars(makes it a little more comfortable)
Shocks front and rear
Old Jan 9, 2001 | 07:55 PM
love250x's Avatar
So if the carrier is the problem how do I fix it?Thanks!
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
Clint Russell
Sep 25, 2015 03:20 PM
merryman
Sep 19, 2015 03:15 AM
