700efi shutting off
Old Oct 11, 2007 | 10:14 PM
DEER HUNTER's Avatar
Default 700efi shutting off
wondering if anyone can help me. i have a 2004 700efi sportsman. you run it for about an hour to hour and a half. it shuts off. wait five ten minutes starts up runs like new.
Old Oct 11, 2007 | 10:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
when you try to start it up, do you hear the fuel pump working??
Old Oct 11, 2007 | 10:24 PM
yes. you crank it sometimes it will spit and spudder then die. when it shuts off after trying to restart it sounds like the fuel pump kicks on again. its not showing any codes. lot of people keep saying sounds like the coil.
Old Oct 12, 2007 | 11:16 AM
OIown12's Avatar
I have a 2007 500 EFI X2 that does that on occasion. When I go from full throttle to quick stop, it dies when I get back on it. Cranks right up though. I think it's just one of those EFI 'bugs' that they haven't completely worked out yet.
Old Oct 12, 2007 | 11:02 PM
this just started happening.
Old Oct 13, 2007 | 01:04 PM
tripleR's Avatar
I have not had this problem with my Polaris 700EFI, but recently had the same scenario with my Rhino. After taking it to two dealers, it was discovered the fuel filter was the problem. Under five bucks and I was on my way.
Old Oct 22, 2007 | 04:06 PM
jp1's Avatar
jp1
I have a 2004 700efi. I have been haveing trouble also. you can ride for about an hour or so then it dies. as if it runs out of gas. let it set for awhile and it starts and runs fine for a while.
Old Oct 23, 2007 | 07:06 AM
jp1's Avatar
jp1
I have the same trouble. I also am looking for help other than the dealer$$$$ they said it could be the fuel pump $ 450.00 plus labor (ouch) their are some codes you can check. turn your key on 3 times within 5 sec. the 3'rd time leave it on it will blink a code # if something is bad. You can call the dealer and ask them what the code is or put it up and i have a list of them.
Old Oct 27, 2007 | 07:34 AM
have no codes showing yet.
Old Nov 12, 2007 | 07:07 PM
'04700efi's Avatar
I have the same problem with my '04 700 efi. The local dealer charged me $90 to tape two worn wires and said it "was fixed", that it showed no service codes and the fuel pressure was good. I thas happened many more time and a shot of starter fluid gets it to hit but it must cool down for 10 minutes then runs fine again for awhile. I talked to 2 other dealers. One said it would have to show codes and the other said the only time he has seen one die without a code showing up was with a bad crank postion sensor that tells it when to inject fuel. This seems the most likely, but could the fuel pump or filter just act up when hot? Other lines on this forum report that there are replacement pumps out there you can use without replacing the whole tank like the dealer says. Has anyone had any experience with this? How bad is it to replace this crank sensor? Thanks.
lonerider856
Oct 13, 2023 03:45 PM
Customer Service #1
May 15, 2020 08:46 AM
mrtidy
Feb 3, 2016 05:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
Matt123
Sep 29, 2015 01:29 AM
