Gas Leaking
Old Oct 15, 2007 | 12:56 AM
Trailboss725's Avatar
Default Gas Leaking
I got old red about 95% built back up and she hasn't had gas in her for about 6 months and this happened before but when I fed gas to the inlet line of the carburetor the gas flows back out of the hole closest to the filter as if the bowl wasn't rising to cut off the fuel from flowing out when it is full. Last time this happened i took it back apart and made sure everything was functioning and then when it was put back together it worked fine. I forgot to mention the bike is on an incline i have the front lifted by a jack and the rear wheels are still on the ground could this be the case??
Old Oct 15, 2007 | 08:03 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Gas Leaking
so are you sure the float needle is seating(shutting off) to stop the flow of gas?
Old Oct 15, 2007 | 02:39 PM
Default Gas Leaking
im gonna pull the carb off to make sure i did put everything back right, but this is the original carb and the bike has been sitting for 12 years so i think it may need a reb. kit.
Old Oct 15, 2007 | 06:19 PM
94harley's Avatar
Default Gas Leaking
It probably needs a new needle valve and float pin and set the float height. They tend to wear. Look for grooves in the needle valve. If you see any, repalce it.
Old Oct 16, 2007 | 01:20 AM
Default Gas Leaking
im gonna pull it apart again tomorrow and check the float height and need valve to see if it needs to be replaced thanks.
Old Oct 16, 2007 | 02:35 AM
Default Gas Leaking
sorry to answer myself but I have been carefully studying both manuals and the leak is coming from the center hole on the bottom of the carb where it hooks up to the air filter box or its called the" idle air passage" is this because I have it running to rich. Also now fuel is leaking out of the overflow line, I think this is all due to a carb being in serious need of an overhaul. Or maybe a simple float adjust and idle air screw adjust??
Old Oct 16, 2007 | 07:51 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Gas Leaking
start w/ a new needle and seat if your in doubt about it. then make 100% sure its set correctly before doing any else.
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
