Yamaha Warrior engine bolts
Where can I find engine bolts for my 95 Warrior? Is there a website or something? I need the bolts where the exhaust bolts onto the head, for the left crankcase cover, and the pullstarter.
thanks in advance
thanks in advance
Check the link below. It's only missing the exhaust studs. Order the exhaust studs from bikebandit.com and you can match up some nuts for the studs at the hardware store.
http://cgi.ebay.com/ebaymotors...QrdZ1QQsspagenameZWDVW
<div class="FTQUOTE"><begin quote>Originally posted by: HONDA CRUSHER 93
Will they have them to fit it? If so, I would probly have to order them wouldn't I?</end quote></div>
You should find most of what your needing at a good hardware store. Yes even the right lengths if they have a good inventory.
The local ACE around here has a good selection of metric stuff, and I have even seen some studs (not sure if there metric or not) but it would be likely you find the studs at the dealer or online like suggested earlier.
Just be sure that the bolts you get are not too long that they cause any damage, and also that you dont over tighten them either.
Also I dont remember exactly but I did swap exhaust studs between honda and yamaha once (sorry dont remember which to which etc) and they did fit and one was twice the cost of the other.
I went to Lowes and got some for mine. My holes were wallowed out a little so I got some one size up from factory. I got stainless steel bolts with stainless lock washers, locknuts, and I use locktite to make sure they don't come loose. Those Warriors are bad about losing bolts!
Thanks guys. Hold on, are the bolts for the exhaust bolts or studs? When I got my warrior it hald bolts. I'll look at ace hardware. Does anybody know the thread size on the bolts or a website where I can find out how long I need them?
