Trouble with winch switch
Old Jan 6, 2001 | 09:52 AM
Pensykodiak's Avatar
The switch on my Warn 2000 makes a noise that sounds like a spark when I use it to raise and lower my plow. It's been doing it since I got it. Last night the switch didn't work and I started the machine and after about 15 minutes it worked fine. Has this happened to anyone. I think my switch is going bad. Thanks for any help.
Old Jan 6, 2001 | 02:15 PM
drincbud's Avatar
i had a similar problem with mine also,i emailed warn and complained .they sent me a new switch under warranty,tell them its less than 1 yr old and they`ll replace it for you
Old Jan 6, 2001 | 07:24 PM
MissouriGriz's Avatar
I've had the same problem that mysteriously disappears after a few minutes of running the machine. My best friend has experienced the same thing. I haven't delved into it very far yet, but it sounds as if there is a loose connection inside the switch, or there is dirt, or something conductive allowing the electricity to arc across instead of through the contacts. When, and if, I figure it out, I'll let you know.
Old Jan 6, 2001 | 09:01 PM
I took the switch off today and there's not much in there. There are 4 connections that are held in place by nuts. It looks fine but it's not. I called my dealer today and he says he'll talk to the mechanic to see what he thinks it could be. I did it again twice today.
toonces
Oct 19, 2015 02:21 AM
user493
Aug 13, 2015 12:54 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
