Loose Scrambler 500 A-Arm
Old Oct 18, 2007 | 04:44 PM
cdrmotorsports's Avatar
Default Loose Scrambler 500 A-Arm
I noticed today that the A-Arm on my '01 Scrambler 500 4x4 was a little loose (it has some play to it). The bushings look good. Is there an easy way to fix this? I tried to tighten up the nuts on the outside, but I don't think I have the right socket and wrench?!?!?!
Old Oct 18, 2007 | 05:55 PM
scramblerXrated's Avatar
if its loose, then your bushings are worn. they may look like they are good, but they need replaced. EPI sells a good replacement set, reasonably priced too.
X
Old Oct 19, 2007 | 09:59 PM
Hmmmm... that isn't bad. Are they hard to install? I have every wrench in the world, but can't find one that fits on those nuts?!?!?!?
Old Oct 20, 2007 | 02:00 AM
once you find the right wrench, its not too bad of a job..... LOL
X
Old Oct 20, 2007 | 04:12 AM
dosceola's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: cdrmotorsports
I noticed today that the A-Arm on my '01 Scrambler 500 4x4 was a little loose (it has some play to it). The bushings look good. Is there an easy way to fix this? I tried to tighten up the nuts on the outside, but I don't think I have the right socket and wrench?!?!?!</end quote></div>
That dont mean bushings are bad they could have rattled loose mine have and bushing is fine just need some loc tite on em. Do u have grease fittings on em? make sure they are full if u have grease gun just couple pumps no more then 2 or 3. if u live somewhere hot then factory loc tite on bolts could have melted off. but if u feel the need then do bushings but not needed in my opinion
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
