Sp carb troubles
Old Oct 22, 2007 | 01:58 AM
edmo500's Avatar
Default Sp carb troubles
Hey guys I havent been on in a while. My 96 Sportsman 500 has some carb problems, the slide wont pull all the way open. It will seldomly and run great. I think the carb is shot. Any Ideas? It has about 4000 miles. New piston rings, cam.
Old Oct 23, 2007 | 01:08 AM
trailblazzers's Avatar
check your cable maybe too much freeplay adj in the cable by the handle bar sounds like may have a hole in your diaphram
Old Oct 23, 2007 | 09:31 AM
edmo500's Avatar
Ive adjusted the cables a few times, I am not sure if that is the problem. I cannot see any holes in the diaphram, but that is what it seems like. If I take the carb apart and reassemble it will usually run good for a while, then its back to no power at all...
Old Oct 23, 2007 | 11:18 AM
sjbr549's Avatar
could have varnish build up from bad gas. take the carb apart and use very fine steel whool to polish everthing.you can get it at wal-mart or lowe's hardware
Old Oct 23, 2007 | 11:20 AM
edmo500's Avatar
The thing is polished and has been cleaned numerous times....
Old Oct 23, 2007 | 11:27 AM
sjbr549's Avatar
could just be bad gas.if the gas isn't fresh in mine it won't run spit,sputters,dies and won't start back for awhile but it's 2stroke also
Old Oct 23, 2007 | 11:30 AM
edmo500's Avatar
I have also removed the tank and cleaned it, also have installed new fuel pump.
Old Oct 23, 2007 | 11:39 AM
TLC's Avatar
TLC
Fuel filter?
Old Oct 23, 2007 | 11:41 AM
edmo500's Avatar
Yep, replaced that too. Its just weird that it will run great at times. But Its definitely a fuel issue. Ive gone through pretty much all I can think of, not really wanting to spend 300 on a new carb.
Old Oct 23, 2007 | 11:46 AM
sjbr549's Avatar
is your jetting right for your altitude
