shift problems
Old Oct 22, 2007 | 10:05 AM
ESRancher20044x4's Avatar
Default shift problems
my 04 rancher es blinks the gear number when i start it and will not shift gears. i shift it thru the gears with the manual shifter and it works til i turn it off. when i start it back up it starts to blink again. can anyone help
Old Oct 22, 2007 | 10:17 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Some of the ES components are the subject of a recall. Check with your dealer....
Old Oct 23, 2007 | 10:25 PM
CountyMounty's Avatar
First of all you need to count the number of times that it blinks, it is a code that tells you what part of the ES system has a problem. It should blink x number of times then pause briefly and then blink again. It will do this over and over again. Not sure about an 04 Rancher but I am having problems with my 07 Foreman ES. It is blinking 3 times, Code 3 means a problem with the angle sensor component which from what I have read is a very common problem. I have a sensor on order hopefully that fixes it.
Old Oct 26, 2007 | 12:07 PM
polaris man's Avatar
check the angle sensor
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
