Weird 2000 rancher 4x4 es shift problem
Old Oct 22, 2007 | 11:57 AM
akp283's Avatar
Default Weird 2000 rancher 4x4 es shift problem
the electric shift on my 2000 rancher 4x4 es doesn't work properly. It starts and runs fine for the first minute or two and then it won't shift anymore. If I turn it off and turn it back on or just put the key in the "on" position without the atv on, it shifts perfectly. I can turn the atv off and back on immediately after it stops shifting and it works perfectly or I can wait, either way, turning off the atv makes it shift fine for the next few minutes. I have checked the angle sensor and it checks out fine, maybe it works sporadically. All of this started when I got the atv almost completely on its side in about 2 feet of water and it shut off. When I tried to crank it the es started its problems and the speedometer stopped working. The speedometer also still isn't working, but I haven't messed with it yet. If anyone has any ideas please let me know. Thanks
Old Oct 22, 2007 | 12:23 PM
HondaMechanic's Avatar
The speed sensor is 1 of the ESP inputs so the electric shift isn't going to work if it is bad ... Turning the igition off & on again re-set the ESP system ..
Old Oct 22, 2007 | 10:05 PM
akp283's Avatar
how do I reset the ESP? I need help with that one.
Old Oct 22, 2007 | 10:06 PM
akp283's Avatar
that is how do I fix the problem? reset the ESP or do I need a new part
Old Oct 22, 2007 | 11:09 PM
Everytime the key is turned off and on again it re-sets the ESP (electric shift program) .. The ESP won't work properly unless the speed sensor is working .. PM your email address and I will email you the section covering the speed sensor test ...
Old Oct 22, 2007 | 11:16 PM
03fabulousforeman's Avatar
My foreman does basicly the same thing but my speed ohmeter works fine. It gets hung up or just doesnt shift, blinks and ****. I have to turn it off and on real fast to reset it. What causes this if the speed ohmeter is working fine?
P.S. Sorry there akp283 no trying to steal you thread bro.
Old Oct 22, 2007 | 11:36 PM
On 2002 and newer Foremans you have to count the flashes ...
Old Oct 23, 2007 | 10:18 PM
akp283's Avatar
its cool fabulousforeman. I was wondering the same thing, if I get the speedometer working and the es still doesn't work right, what's the next step? But i will try the speedometer first.
KimSJoh
14
Jul 18, 2015 07:20 PM
coolguy420
Jul 10, 2015 01:17 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Mikea1978
Jul 4, 2015 12:37 PM
